UPDATE Jan 18, 2022: Datalog posted (Post #15)
Before you say anything (no bashing plz), tuner is an expert on GTRs in the Middle East. Tuner himself owns 5+ R35s so he knows what he's doing... but yes sometimes errors are made and I'm here to ask for your advice on Boost cuts and timing pulled that I'm facing often during hard pulls.
So since my new built short block, turbos, trans etc (Alpha 9) I've been noticing gauge flashing and timing pulled during hard pulls. Usually -2 to -4, but recently had 2 boost cuts around 6,500rpms, with -5 pulled @ 21 psi (map 0, around 720-740whp) and it's quite embarrassing and annoying. I raised the issue with my tuner and he informed me that: Yes he did adjust up to -5 pulls for knock safety, and also mentioning that with my current power and cold weather, no humidity at the moment, the extra O2 can cause cuts. He said he can fix that issue by retuning, but the car would have less power. One thing to note: over here we run 95 RON pump gas, and it's not the best.
Last night did a pull, with a boost cut and also got Limp Safety 16, which is "KNOCK"
I'm here to ask, is that something common or a tuning issue? is up to -5 timing pulled "without boost cuts" normal and safe for the engine? What are some solutions? Thanks
