1 - 20 of 20 Posts
So my car is almost ready to be started up.. Few more days and we should be good to go as long as their are no headaches. Just wanted to know if people just start up the get the car running and idling on regular cheap Dino oil to get it running and idling and maybe just drive it around very slightly for a little bit then drain it and replace with a higher quality oil.... is this a problem?
Mark
That's what I did for my Z, but you got a GTR where it runs Mobil 1 0w-30 I believe from the factory, so just run the mobil 1. Just my two cents. Also, since it's a new engine, PRIME the engine before the first start up to coat the engine.
yea definitely going to prime the engine up... Ill just do the 0-40w or Mobil one i guess for the first couple changes... which ill do quickly.
ill used mobil one ..
Hope I helped a bit. lol If you don't mind me asking, is the specs going to be the same as the new engine?
Its a boost logic Stroker engine with a set of Head games heads all done up. Boost logic Turbo kit etc.
so u got your head ported also..
yes head games did an excellent job on the heads... Ported, complete ferrea valve train setup, B-Series Kelford Cams,..
Testing out these new CEA Turbine wheel Precision turbos. See how they go. Should spool very hard and fast, especially with the stroker.
Discussion Starter · #11 ·
yea man... been way too long.. really hope everything goes smooth with no headaches.. or nothing major at least. Just want to enjoy her again and cruise around and go to all the car meets out here... the big power will have to be put on pause till the money for the transmission build comes in.
congrats Mark! Can't wait to see those #'s!
Congrats I would just warm it up and dump the oil and filter, then re fill and do break in. Worked well for the supra motors
Congrats Mark! I should have gone Boost Logic kit myself. Sounds like a Monster setup!
sickk set up ya def prime it and id just run the stock oil... also is this joe? Jon aka Gimpy works for me he always talks about your car
Discussion Starter · #16 ·
Nope my name is mark.
Discussion Starter · #17 ·
Joe C. lives out your way with the boost logic setup as well that tears up the streets.... his car is nasty too.. ill be meeting up with him to roll once I'm back up and running.. he's a good guy. Im sure we will cross paths ill be going to all the meets and what not.
Thanks.. when you car is done well def do some rolls. cant wait to see it all back together
About time ;)
Im Joe lol... We gotta link up sometime. Im right in westbury so not far at all
haha wooops!! oh ya awesome duh lol you where supposed to come to the track with us correct? matt was doing a rental
1 - 20 of 20 Posts
