Khiem from MotoIQ posted an article detailing some modeling he did of hard braking for a shorter amount of time vs lighter braking for a long time.
Check out the article.
http://www.motoiq.co...brake-fade.aspx
One of the charts.The lesson here is that harder braking is better. Either you end up going faster and have basically the same rotor temps, or you go the same speed with lower rotor temps as compared to being too light on the brakes. Lower rotor temps should translate into less brake fade and also lower pad and rotor wear. Harder braking means less time on the brakes too, so that may also translate into less pad and rotor wear. So don't be afraid of the brake pedal and stomp on it!
