broke my transmission
5082 Views 8 Replies 7 Participants Last post by  Shep
guys,
need help!!!
I live in Dominican Republic and I broke my 2009 GTR R35 transmission while doing a launch control mode start.
I need to send the transmission to the USA to repair and possibly to upgrade so it does not brake any more doing launches.
please advise best options to upgrade (with least money investment) and fix.
can someone recommend where I should send it and what should I upgrade???
thanks in advance,
Luis Gigante
Dominican Republic
1 - 9 of 9 Posts
guys,
need help!!!
thanks in advance,
Luis Gigante
Dominican Republic
Do you have LC1?
http://www.2009gtr.com/2010/12/used-nissan...-2009-2011.html
Launch control is enough of a controversy with the Nissan GT-R, that it is worth its own section. The first launch control on the GT-R was called LC1. LC1 would allow for 4500 rpm launches. VDC off, transmission up to temperature. Without launch control the car would come off the line at 2000 rpms. The problem with the 4500 rpm launch, was wheel hop. The GR6 transmission as used in the GT-R was the first production use of an longitudinal dual clutch transaxle. By September 2008, the first pictures of failed GR6 transmissions were floating around the web. The first failures seemed to be a catastrophic failure of first gear.
By October 2008 there were a few individuals that had transmission failures, had switched VDC off, and were denied warranty claims. A few owners started calling for a class action lawsuit. Lots of controversy erupted. At the end of October, I posted a few options on ways to fix the GR6 transmission and launch control.
In December 2008, Edmunds Inside Line tested their GT-R with the 4500 LC1, and with a non VDC off, 2000 rpm launch. With LC1, they saw a 3.53 second 0-60 time(1 foot of rollout), and a [email protected] mph 1/4 mile. From a 2000 rpm launch, they saw a 4.3 second 0-60 time(1 foot of rollout), and a [email protected] mph pass.
In January 2009, Edmunds Inside Line reported that Nissan was going to be reprogramming the launch control on the Nissan GT-R, we would start to call this reprogrammed launch control - LC2.
- Launch Control remains, but the maximum allowable engine speed with the VDC system switched off will be reduced from the current 4,500 rpm to between 3,000 and 3,500 rpm. The clutch engagement program will also change to reduce driveline stress, e.g., less abrupt engagement on launch.
- When launching with the VDC on, the new programming will allow for higher engine speeds and a more aggressive clutch engagement than the current setup.
- Nissan reiterated that launching the GT-R with the VDC off is not covered by the warranty.
Some owners with LC2, saw 0-60 times actually decrease to the low 3 second range. Here is a video of one car 3.1 seconds 0-60 mph.
By September 2009, Nissan had settled the transmission warranty claim lawsuit. Here are the results of the lawsuit.
1-All GTR owners that have LC1 used before and were afraid that the tranny did not have any warranty because of turning VDC off and doing a LC1 will have their warranties re-setted for 5yr or 60k miles if they upgrade to LC2. All LC1 will be forgotten and the tranny will be fully covered by NISSAN. After LC2 being installed, all LC2 with VDC on will be fully covered by NISSAN. If you turn VDC off today , do your thing ( drag/road course/etc) and the tranny goes bad at that moment, the warranty will not hold, BUT if the problem arise some time later after turning VDC off back on and driving the car without any issues and then BAMMM.......the tranny will be covered 100%. If not NISSAN WILL HAVE TO PROOF that turning VDC OFF a week or a month prior the damage was the cause of failure. THEY WILL NEED TO PROOF IT , not like before that they just saw the BB data and said it was not covered.
2- ALL 2009 GTR owners will get a $75 coupon for any kind of service at any GTR approved Nissan dealership as part of a class compensation for the time taken to update LC2.
All this will be happening in the next 2-3 months when GTR owners will be receiving notification from NISSAN.
VDC Stall Start log from Consult III
For 2011, the Nissan GT-R launch control got further improvements, which we called LC3. LC3 would allow for a 3300 rpm VDC in R mode launch, making the launch covered under warranty.
In 2012(US), the launch control was again revised. This time it is an actual advertised feature, called R Mode Start, with limits. LC4 allows for four launches prior to it requiring a mile and a half drive to cool the transmission down. The quick numbers are generated with the setup switches in R- Comf - R. 4000 rpms comes up, and 0-60 times happen in anywhere from 2.8- 3.2 seconds.
A Nissan dealer can use the Consult III to get a printout of VDC off(possible launches), and also transmission temperature logs. This leads to the next area of concern, the GR6 transmission.
Do you have LC1?
yes. I have an LC1 program. also I have 600 AWHP so probably that helped breaking it.
Thanks for all the info.
very much appreciated.
which 1st gear upgrade do you recommend???
sincerely,
Luis Gigante.
probably?
Dude build your tranny from SHEP Trans and change the launch control. please.
Greddy USA, Shep Trans, SP Enginnering.....I would pick one out of those 3.
For gear set, albins or ppg. Anyways call one of them and ask for your need.
ouch i feel for you man, when i broke my GTR's transmission it was back in feb 2009, i had to get on a list to get my hands on a PPG 1st gear. that was crazy, now you can get that shit fixed in a week and back up and running.
LOL sorry, the news does suck, but once I read to "2009" I kinda derped.
have you heard of AAM Competition? and Forged? what's your opinion on them?
I've called Shep Trans but cannot get a hold of John.
whats your opinion on the 1st gear...arbins, dotson or PPG/ which one is best?
thanks for your help
Sorry , we were at a race all weekend and just made it back to the shop. I have replied to your email
1 - 9 of 9 Posts
