They shouldn't give you any TC issues, but your fender gap will increase by approx 1/2 inch, along w/ the entire car abt the same (if approx 1" shorter than stock tire) closer to the tarmac.
They shouldn't give you any TC issues, but your fender gap will increase by approx 1/2 inch, along w/ the entire car abt the same (if approx 1" shorter than stock tire) closer to the tarmac.Will there be any issues with running the following tire size? Its the oem width just lower height tire:
255/35/20 (27.027" diam)
285/30/20 (26.73" diam)
They are within the 8mm and/or 0.31" height difference recommended sizing from the manual. It seems like they will have a shorter sidewall and about an inch less height than the oems. Will this drop the car or just increase the fender/wheel gap or both. Would not want the fender gap to be any larger than stock but don't mind the overall car being dropped a little. Please advise.
It will also affect your speedometer reading..They shouldn't give you any TC issues, but your fender gap will increase by approx 1/2 inch, along w/ the entire car abt the same (if approx 1" shorter than stock tire) closer to the tarmac.
