1 - 7 of 7 Posts
Just had my car fixed with a hole in the passenger side inner boot. They replaced the whole axle as well. I was warned by my dealership that the springs may have been the culprit and if it were to happen again, the springs may cause static for a second warranty fix. After just 40 miles, I found another hole in the driver side this time. Too coincidental to be just failing boots so I can't help to think it is the springs. Also, can I assume Nissan will deny this fix? Swift rs by the way, on a 15.
· R35 member
The only thing I can think of where the two would be related, is that maybe by lowering the car it's changed the angle of the axel slightly. Just stick your head under there and see if the boot looks like it could come in contact with something. By lowering the car could also change the distance that the body travels in up and down motion but I don't see where that would impact the boot any.
Sent from my SM-G900T1 using GT-R Life mobile app
I also forgot to mention, it's a pin hole, not a rip. Both times. That eliminates the contact question, which I assumed at first too.
I read somewhere is to place a dab of gorilla glue over the pinhole and that might save u some time.
It will also prevent grease from getting all over the wheel wells.
· Knowledge is recession proof!
Dabbing Gorilla glue is a good idea. The leakage is usually from a pin hole and not a linear tear. Clean it up and find out, it may save you A LOT of money. The defect is not usually caused by lowering springs, but the installation of the springs. Most knowledgeable shops will use some type of rope to keep the axles up when removing the suspension. And others will just have them drop down which will cause excess angle/stress to the boot. Hence the tear, etc.
1 - 7 of 7 Posts
