Cicio Performance Drag Wheel Special!!!!!
Choosing the right wheel & tire combo for drag racing is essential to running a great time and the Cicio Performance Drag Wheel Package is perfect for that.
Our exclusive wheel design is built right here in the USA by Billet Specialties which undergo a very stringent process to ensure you get the best quality wheel possible.
Utilizing proprietary 6061-t6 forged billet aluminum centers allows them to manufacture the highest quality and strongest wheels possible.
All B-Forged near-net raw forgings start off with the lathe operation. This process prepares the forging for machining the design into the center.
Utilizing the latest CNC machinery and tooling along with over 30 years of experience, each forging begins with the turning operation in one of their CNC lathes. The resulting wheel centers are then transferred to the milling department where they are precision machined to exact specifications.
All finishing is performed in-house at Billet Specialties. Powder coat finishes start with careful surface preparation followed by thorough cleaning to remove any contamination. The powder application in their clean environment and precise cure times in the oven, result in one of the finest finishes available in the industry.
Before the assembly begins, each wheel component is meticulously inspected. Once assembled, both the lateral and radial run-out is checked to ensure a vibration free wheel. Final fastener torque is completed and the sealant is applied to the thoroughly cleaned surface.
Features and Specs:
Price is per set of 2 wheels
Cicio Performance exclusive design built in the USA by Billet Specialties
Clears factory rear brakes (17" and 18" Wheels only)
Forged 6061-T6 aluminum
Welded 2 piece design
Lowers rotational mass by saving almost 20lbs per side from the factory wheel/tire
40+ finish options available
Polished and Custom Finishes available for $250
Standard polished lips with optional color matched lips available
All tire packages include mounting and balancing
Retail Pricing Starting at:
15" Beadlock - $1895
17" Non- Beadlock - $2095
17" Beadlock - $3095
18" Front - $2195
18" Rear - $2695
Use code "cicio5" for an additional discount!!!
Tire Packages Available as well!!!!
Link to Wheels:
https://cicioperformance.com/product-category/nissan-gtr/wheels-gtr/
Let us know if you have any questions!!
