My obsession is your gain. Having been told that on the 2011 model that a backup camera that automatically switches when reverse is engaged was not available or possible, I set about finding a solution. You can read more HERE where I shared my discovery for all to see.
Highlights:
When comparing kits please remember to ask:
Highlights:
- Uses a plug and play harness that is as easy to remove as it is to install (unlike other kits that copied that just give you pins to insert)
- Installed in 2-3hrs
- Full step by step instructions with lots of pictures
- No soldering
- No cutting of any wires
- Uses factory software with on-screen guide lines
- High Quality Kenwood Camera (not a cheap license plate camera from ebay)
- Quality of the cameras being used - We use Kenwood CMOS-210
(We've tested lots of the cheaper alternatives and still use what we think is the best) - Does the kit come with a true plug and play harness - Our kit has a plug and play harness and not just two pins that must be put in the existing car harness
- Does the kit require and wire taps for example for the power - The plug and play harness in our kit supplies the power and no wires need to be cut or joined.
