1 - 6 of 6 Posts
Founder/Admin
I have a 2015 GT-R and every time I start my car up the climate control is set to 75 degrees and the "feet vents" selected, rather than what I had the controls set to when I turned the car off. I did some searching and it appears that other members have complained about it. Is there a fix for this, or is it something I'm going to have to deal with?
fuse box by your left knee. there will be a big white fuse sticking out...push it in
I tried that (multiple times), but unfortunately it didn't do anything. It was already pushed in when I checked, so I pulled it out, started the car, and then changed the settings and turned the car off. I turned it back on and the settings didn't save. I turned the car off, pushed it back in and tried again (and another time with it out once more).
Navigation unit software upgrade ,could be help
I know there's a temp sensor under the dash that if not connected has a similar effect. It would be just in front of your right knee on that panel
'15 GMG
1 - 6 of 6 Posts
