1 - 2 of 2 Posts
Hi, dashboard lights are going down one by one, first was the fuel , after that water temp now its gears gauge turn
I dont know if this is releated but doors autolock doesnt work anymore, even the cd,dvd,usb,music box, doesnt work
in the video below i tried this solution that wroe in a thread but as u will see nothing happened
[background=rgb(246, 246, 246)]"To activate or deactivate the automatic door lock[/background]
[background=rgb(246, 246, 246)]system, perform the following procedure:[/background]
[background=rgb(246, 246, 246)]1. Close all doors.[/background]
[background=rgb(246, 246, 246)]2. Push the ignition switch to the ON position.[/background]
[background=rgb(246, 246, 246)]3. Within 20 seconds, push and hold the[/background]
[background=rgb(246, 246, 246)]power door lock switch:[/background]
[background=rgb(246, 246, 246)]. to the LOCK position for more than 5[/background]
[background=rgb(246, 246, 246)]seconds to enable or disable the automatic[/background]
[background=rgb(246, 246, 246)]lock function, or[/background]
[background=rgb(246, 246, 246)]. to the UNLOCK position for more that 5[/background]
[background=rgb(246, 246, 246)]unlock function.[/background]
[background=rgb(246, 246, 246)]4. When activated, the hazard indicator will[/background]
[background=rgb(246, 246, 246)]flash twice. When deactivated, the hazard[/background]
[background=rgb(246, 246, 246)]indicator will flash once.[/background]
[background=rgb(246, 246, 246)]5. The ignition switch must be turned OFF and[/background]
[background=rgb(246, 246, 246)]ON again between each setting change.[/background]
[media]https://www.youtube.com/watch?v=MYJmCK-4igQ
1 - 2 of 2 Posts
