recently I've had an issue with knock on the OTS Stage 1 map where the boost gauge will occasionallyl flash. I went back to the OEM map and would occasionally would go into low boost mode which made me think that the problem might be poor fuel quality (I live in So Cal and only 91 is available). Anyway, I'm still not sure if it's the fuel, hot ambient temp etc. Which parameter is used to assess for excessive knocking? Is it the DA? I've used Torco as well as adding a little E85 to the tank (1 gallon on a full tank). I read a thread where it was considered to be safe to add a little E85 to help with knocking but since I'm on stock injectors, I didn't want to push it. Last time I data logged my IDC was 97%.
car has catless MP, catback, 2.75 CAI
Thanks
Thanks
