1 - 9 of 9 Posts
Just picked up a set of DBA Replacement rotors for my GT-R (DBA52370.1S). They did not come with replacement hardware (nuts), contacted the seller and he stated they do not come with them anymore.
Has anyone had the same experience??
Can the old nuts be reused?
Anyone know were I can source DBA replacement nuts they used to include with their rotors?
thanks in advance.
Kevin
Link above is a rip off and at $12 each that would cost over $400 lol because you need 36 sets total. Refer to this below:
A: Yes, they are M6x1.0 Bolts with a 30mm thread length. You can pickup the Class 8 or 10.9 hardware at Ace Hardware/ True Value or at online resellers like McMaster-Carr. Nissan uses Blue liquid threadlocker on the bolts from the factory, so I would suggest the same.
Here are two links for Class 10.9 replacement bolts & nuts:
https://www.mcmaster.com/91306A675
https://www.mcmaster.com/3528N11
https://www.amazon.com/Permatex-24200.../dp/B0002UEMZ2
In Europe the DBA replacement discs still come with replacement locknuts. The discs themselves look to be of good quality and are attractively priced. A few caveats though: The DBA EU distributor took 3 months to deliver them due to COVID and I've unfortunately had to leave the car with my mechanic because the bolts could not be reused due to the fact they were impossible to tighten to the correct torque because the bolts were heat damaged (They were a nice shade of blue and they stripped when he attempted to torque them down to the specified 13nm. I didn't think that I used the brakes THAT hard. :)) He had to order 4 sets of AP bobbin kits (one set per disc) from Germany. (Expected delivery in 3 days and yes, I know that they're M6x1.0 Bolts that probably could be bought much more cheaply separately, but these are a critical point of failure item and the local hardware store might not have the correct quality.)
Frankly, if knew that this would occur, I would've ordered some J-Hooks from AP because they come with hardware. We're locked down here in Europe and my installer is across the border. We have to get COVID tests to cross borders so I'll have to get another COVID test to pick the car up next week. The price of the bobbin kits and the inconvenience incurred negate any cost savings.
In closing I have to thank Petr and his team at Auto-Impex for their excellent and knowledgeable service. If you need some work done on your GT-R in Central Europe they're the people to call.
Member
1 - 9 of 9 Posts
