Hi Guys - relative Newbie & apologize for such a basic set of questions. I am looking for details on changing the various Flids in the GTR; Becaue of their routine nature, I got the engine oil & filter, engine coolent - drain and flush - Freon 134 ? charge, etc.
But i don't see anything in th owners manual about how to check for tansmission oil levels, or diffs. I have bits and pieces of the Shop manuals, but some of it doesn't make any sense. ie. on the trans; It says to remove the fill and drain plug and add trans fluid R-35 till it runs out the drain hole, but the drain plug is the low point, so wouldn't it run out of there pretty quickly - befopre any adequare fill - Another location in the pubs indicated there a fill tube in connection with the drain plug, which would make sense that it was filled till it hit the top of the fill tube and out the drain plug hole - but I don't have a fill tube at the drin plug in my 2009.
And yetr another location, say to fill until you can put your finger inside the fill hole and feel the level. I didn't find anything on the trans or diffs that i could fit my finger in, and that it relatively in preciuse, since you finger will be getting oily going in and hard to detec the oil level.
And lastly - since there isn't a fill tube from above for the trans or either diffs, I imagine that all 3 liquids have to be pumped in ?
Many thanks,
Many thanks,
