Thanks, yes I meant the OEM carbon flat panel that fits under valance with the cutout for part of the exhaust.IF you mean the carbon panel, yes the original Zele one does.
+1 on that...David, does the difflow diffuser replace the carbon panel?
Yep. Glenn made a vid showing how it fits. So as long as the replacement carbon valance is designed to fit above the stock carbon panel, the Difflow should fit beneath the valance: http://www.nagtroc.org/forums/index.php?/topic/64863-how-to-install-difflow-rear-diffuser/David, does the difflow diffuser replace the carbon panel?
difflow is the direct replacement, if it fits the stock, it should fit anything out there that fits the stock Carbon Flat panel.+1 on that...
Thank you David & m3RYep. Glenn made a vid showing how it fits. So as long as the replacement carbon valance is designed to fit above the stock carbon panel, the Difflow should fit beneath the valance: http://www.nagtroc.o...-rear-diffuser/
