1 - 13 of 13 Posts
I'm looking for a drag / street setup, I currently have 20" Nismo Wheels and want to switch out the rears for either a 18" or 17" wheel if the 17s will fit over my ZR1 CCB. Appreciate any recommendations. Fronts have MPSS 285/35/20
2020 Bayside Blue
Reach out to Belak Industries for fitment I believe it will fit. The rear caliper bolts are changed out for some ARPs. I have a set sitting in my living room waiting to be put on the car.
You probably know this, but for others let me just make a simple comment. Most of us would like to have the best of both worlds without changing tires/wheels, but If you move toward better drag characteristics with one set-up only, you typically sacrifice routine drive ability. We all make choices...
Alexd
Alexd
I can use my stock wheels for regular driving, really looking for a street drag wheel/tire.
How much power are you looking to put down? Let's start there...
From a dig, you can get away with a set of 18's and drag radials at all four corners. Mickey Thompson ET Steet S/S with 275/45/18 in front and 345/40/18 rear, presumably with a set of 18x10 and 18x12. That's a tried and true street/strip setup.
M&H also makes an equivalent set of their drag radials in nearly identical sizing.
Or...
You can go with a 17x10 beadlock rear like they offer through Cicio Performance. You'd want to throw a Mickey Thompson ET Street R in 305/45/17 and you can run any 18" wheel/tire up front, so long that it's 28" outer diameter. They make a matching non-beadlock 18" front that clears factory brakes. People have run well into the 7's with that combo on a well prepped surface. As MiamiBert said above, the caliper bolts need to change to accommodate the reduced wheel diameter but beyond that, no other modifications should be required.
Or...
Looking for something more to run on the street, I know my drag options. This would be for the occasional dig on the street/unprepped road, but mostly 60-130 runs. Primarily looking for WHEELS that will go along with my 20" OEM Nismo Wheels.
Discussion Starter · #10 ·
Well might not be getting wheels now I think I need a new headgasket
Damn sorry to hear !!! Hopefully nothing major.
We will find out for sure when I change the oil when it comes in but I actually think it's fine my tuner said what came out of the catch can is prob just oil and water from condensation / being on ethanol as it produces about 2 gallons of water per gallon of ethanol.
Anyone care to chime in really looking for a street racing tire? I'm between MT Thompson Street SS 305/35/20 / NT555RII 305/35/20 (Rears) and NT555RII 305/35/20 / Toyo R888R 305/35/20 (Fronts)
1 - 13 of 13 Posts
