1 - 13 of 13 Posts
Like a BOSS
After breaking the spline part of my left rear CV joint at the dragstrip about 3 weeks ago I gave Shep a call to place an order for the larger DSS axles and stronger stubs. I received the kit last week and installed it this past weekend.
After removing the rear wheel/housing assemblies and stock axles I removed the stubs located in the rear diff by knocking them out with a slide hammer (a snap ring holds the stubs in place).
Using a large 2 jaw gear puller I removed the ABS rings from the stock stubs. I then pressed the ABS rings onto the new DSS stubs and knocked them back into the rear diff on each side.
I decided to bolt the wheel hub/housing assembly back in place first, then I unbolted the CV joint/spline part from the DSS axles, and slid the CV joint/spline part into each wheel hub/bearing assembly. Unfortunately one of the bolts I removed was cross threaded from DSS, so I had to go get a replacement bolt which was not easy to find since it was a M10 socket head type bolt.
Now with the 2 CV joint ends in place I simply had to bolt the larger DSS axles in place at the recommended 57 ft lbs.
So far everything seems to be working ok and I have not noticed any difference on the road. Hopefully these new parts will give me one less thing to worry about when launching the car at the dragstrip.
Like a BOSS
Discussion Starter · #2 ·
I would still like to repair my left rear stock axle. Most people break the axle shaft and not the CV joint/spline like I did.
So... if anyone has a broken left rear stock axle laying around please send me a PM. Thanks!
Sorry to hear about the troubles! What led you to make a decision on what to risk - the diff v. the axles?
Like a BOSS
I was launching it hard (5800 rpm) and was not surprised when it happened. I've got a brace on my diff, so I hope it can handle the job of keep the case in one piece. Normally when I break a stock part I will spend money on upgrading it if a viable option is available.
Wow launching @ 5800rpm is that with or without BOTL
Nice write up by the way.
Banned
Mike, you are lucky! When my axle stub broke it got the lip of the diff housing and therefore the seals for it. I had to send mine back to Shep to figure out what to do to repair it!
DSS axles are a good safety measure, we usually have them in stock at Titan
About 3 hours if everything goes smooth. My new stubs needed some extra coercing to get back into the trans so I had to chill them in the freezer and go out to buy a bigger sledgehammer
Seriously?
I have a 8 or 10 pound slide hammer, no idea if I'll be comfortable beating on them with a sledge?
Thanks for the response. Any tips from the school of hard knocks? This will actually be the first work I've ever done on my GTR, I haven't even changed her oil yet. (plenty of Toyota experience)
1 - 13 of 13 Posts
