The first batch of Eibach Nissan GT-R sway bars are now in stock. If you are looking for a more economical solution for adjustable sway bars for your GT-R the Eibachs are a great choice.
TECHNICAL INFORMATION
FRONT:
OE bar: 34 mm (1.34 in) tubular
OE measured bar rate: 95 N/mm (541 lbs/in)
OE bar weight: 5.5 kg (12.1 lbs)
Eibach bar: 35mm (1.38 in) tubular and adjustable
Eibach measured bar rate: 2 position adjustable
P1 = 171 N/mm (975 lbs/in)
P2 = 184 N/mm (1049 lbs/in)
Eibach bar weight: 5.8 kg (12.8 lbs)
Bushings: New urethane bushings with grease grooves.
End Link: OE
Approximate installation time: 1.5 hr
REAR:
OE bar: 14 mm (0.6 in) solid
OE measured bar rate: 3.7 N/mm (21 lbs/in)
OE bar weight: 2.0 kg (4.0 lbs)
Eibach bar: 16mm (0.63 in) tubular and adjustable
Eibach measured bar rate: 5 position adjustable
P1 = 5.0 N/mm (29 lbs/in)
P2 = 6.0 N/mm (34 lbs/in)
P3 = 6.8 N/mm (39 lbs/in)
P4 = 7.4 N/mm (42 lbs/in)
P5 = 8.0 N/mm (45 lbs/in)
Eibach bar weight: 2.5 kg (5.5 lbs)
End Link: OE
ANTI-ROLL-KIT Part# EIB6389.320
• Performance Tuned Sway Bars for Improved Handling and Reduced Body-Roll
• Perfectly Balanced for Optimum Neutral-Steering Handling and Precise Turn-In Response
• Precision Engineered and Calibrated for PRO-KIT and SPORTLINE Performance Spring Kits
• Eibach Hi-Tensile Steel Alloy, Cold-Formed, Tempered and Shot-Peened for Long-Lasting Performance and Durability
• Greasable Urethane Bushings For Increased Responsiveness
• Precision Forged Ends and OEM Style Pressed Bushing Locaters (No Welding Or Weak Points Here)
• Million-Mile Warranty
http://www.stillen.com/product.asp?id=EIBA...&model=GT-R
