How is:
Ride quality? (most important to me)
Lowering amount?
Lowering amount?
Sweet- I wanted a conservative drop. 0.8" front and 0.5" rear sounds pretty goodIt's similar to stock ride quality. less than an inch drop all the way around. It works fine for me.
That's exactly what I'm looking for-a subtle drop. Another reason is also to reduce the wear on the shocks.They ride great & perfect the stance but don't slam it. You really don't see the difference until you're parked next to a stock ride height car
reduce the wear on the shocks? you'll be increasing the wear on the shocks with any aftermarket lowering springs.That's exactly what I'm looking for-a subtle drop. Another reason is also to reduce the wear on the shocks.
Very true but the lower the drop the closer you are to bottoming the shocks on potholes and bumps.reduce the wear on the shocks? you'll be increasing the wear on the shocks with any aftermarket lowering springs.
