Error code P0776 : PC SOLENO ID B
18K views 15 replies 7 participants last post by  jaspergtr
hi guys finally i finished my car and what i have done is :
Dodson Gear Selector Piston 1 Sensor
Dodson Gear Selector Piston 2 Sensor
Dodson GR6 Line Pressure Sensor v2 Package
Dodson GR6 Valve Body Clutch Solenoid
Dodson GR6 Valve Body Main Solenoid
Dodson GR6 Valve Body Oil Pump Solenoid x2
Dodson Oil Pump Upgrade and Blueprint Service for GR6
Dodson Reusable Transmission Filter
Dodson GR6 High Performance Transmission Fluid / Oil (10 Liters)
Dodson Clutch Shaft Piston Seals
Dodson (Borg Warner) GR6 Transmission Primary Pan Pick-Up Filter
with all this stuff all i fixed my car , but now i found on erorr on my tranny it's : Trans Pressure Control Solenoid Stuck On P0747
Now i need this solenoid 1,2,3,4 and pressure a solenoid, but i don't know the name off them in the garage they told me (shift solenoid) its control Position sensor 2-4.
Not sure which one this is... Any details about the actual part?
