1 - 5 of 5 Posts
Yes, roll windows down then gently pull it upwards, beginning with the doors side. It's cliped.
I usually remove the mirror triangle first from the inside and pull from that end because you can spread the molding a bit to help it come off. It has a metal frame inside the rubber of the actual piece. Also you have to remove the door panel to get the triangle off
thanks for the answer, but what do you mean by ''beginning with the doors side''?
sorry I meant beginn with open end not the mirror end
1 - 5 of 5 Posts
