A little back story. Car originally modded with HKS Mid-pipe and Cobb Acessport Stage 1 map. Car ran fine for several months, never tracked just some street use as it is my fun car.
Decided to get an HKS legamax exhaust and Cobb SF intake. Took it to my Nissan tech at the dealership and had this installed along with oil change, diff and transmission service. Car has about 12K miles and is a 2009.
Picked car up and transmission was clunky and car made no boost. Since it was after closing, I brought the car back the next day. TCM map never took because their consult-III was broken and this took over a month to get their consult fixed. all the time we were thinking car in limp mode because of TCM. Well turns out the right turbo isn't making boost. Pulled the turbo to see it is failed. Nissan NA wanted pics and their engineers said there was no mechanical failure and denied warranty because of accessport. I went to dealer and got pics of the turbo.
Looks like the compressor side is shredded, and the turbo side is ok. Is this caused by a foreign object sucked into turbo or a mechanical issue?
My suspicion is something got sucked into the turbo accidentally during the intake install as it had always had just the stock airboxes. The car was running perfectly when I dropped it off and pick it up with a turbo failure? This doesn't happen from the Cobb MAP. Any thoughts on the pics?
