Went to the dragstrip for the first time with one of my gtr buddies tonight and boy were we in for a surprise.... Absolutely terrible prep and an extremely bumpy and uneven strip. We were both spinning like crazy (me on stock runflats, and him on 285/335 mpss).
The first run i left it in auto and it bogged as it shifted from first to second way too soon as a result of the wheel spin.
Second, third and forth run i shifted it manually but let it hit the limiter a few times to avoid the bog. Every time this happened the boost would drop from the normal 13-14 psi to 9.5-10 psi MAX for the rest of the run.
After the second time this happened I plugged my odb2 scanner in and used torque to see if the car had any codes. It said there were 2 "Pending Faults" P0101 and P010B.
I cleared it and went down the road to a nice empty long road and did 2 launches all the way up to 80-90 mph. The car hooked perfectly both times (on normal pavement) and hit full boost every time. Went back and did another run on the "prepped" strip and the same thing happened ....
Has anyone had this issue before / know what causes it? I found a thread where they said it may be dirty maf sensors, but that doesnt really make sense due to the fact that nothing has been touched in the engine bay for the past 2k miles if not more. Not to mention the fact that I have launched the car a few more times on the way home to see if it happens again, which it didnt.
Current mods to the car are MP,Catback,2.75" Intakes
Here's a video as well. Not sure if it helps or not.
Thanks,
Adrian!
Thanks,
Adrian!
