I'm not sure how everyone says the 295 fit when lowered. My tire sticks out 1/3 of an inch past the fender and rubbed at stock height.. Unless you run crazy camber, I do not see I wouldn't rub when lowered, specially 1 inch with swift springs...Most I would ever do is a roll. Pulling the fender may cause waves in the metal. There's no way to avoid that. And I'm OCD, so that would kill me.
I'm not sure who told you the 295s will fit up front, but they don't. You can "make" them fit, but effing around with the fender bolts, etc. But at what point will you hack up the car? 285s is as far as I'd go in the front. And that's considering the wheels are proper fitment (20x10 +35).I'm not sure how everyone says the 295 fit when lowered. My tire sticks out 1/3 of an inch past the fender and rubbed at stock height.. Unless you run crazy camber, I do not see I wouldn't rub when lowered, specially 1 inch with swift springs...
