1 - 5 of 5 Posts
Just added to our R35TT.com store! This fuel pump system has been great for us. We use it in a lot of our builds and haven't had any trouble with them. The full options / specs are on our site for order, but always call / pm / email for GTR-LIFE pricing!
http://r35tt.com/sto...le-triple-pump/
Peripheral Input device Gadget Camera accessory Font
Bicycle handlebar Automotive lighting Bicycles--Equipment and supplies Bicycle part Gadget
Automotive lighting Circuit component Audio equipment Font Cable
Automotive lighting Circuit component Hardware programmer Audio equipment Font
Description
  • Triple pump module
  • Operate with two or three pumps
  • Supports 1600+ awhp
FITMENT:
Nissan GT-R R35
SPECIFICATIONS:
Feed Port: -10 o-ring
Return Port: -8 o-ring
Pump Types: 36mm, 39mm, and 39/50mm pump bodies, call for details
INSTALLATION AND USE NOTES
  • Must use upgraded feed/return fuel lines.
  • External 10 micron filtration must be added (this is included in all our complete fuel systems for the GT-R)
  • Choose FC3 to stage pumps using OEM triggers (run one pump full time)
  • OEM transfer function is retained (which continuously transfers fuel to the pump side) but our module eliminates the restrictive "basket" in the OEM fuel pump assembly. We recommend 1/2 tank minimum for track use.
FEATURES
  • Supports over 1600 all wheel horsepower
  • E85 and race fuel compatible (see pump manufacturer recommendations on fuel compatibility)
  • Requires aftermarket fuel feed and return lines
  • Retains OEM level sender, temperature sensor, and transfer function
  • O-ring pump seal eliminates in-tank fuel hose to completely eliminate failures in E85 and race gas applications
  • High current hermetic wire seal completely eliminates the possibility of fuel smells and leaks
  • 12 gauge power wires ensure maximum pump performance
  • Polymer pump support minimizes pump noise and eliminates electrolysis
  • Transfers without restrictor orifice on return discharge, ensuring accurate fuel pressure under any output or consumption conditions
Contact us for dissimilar pump configurations. (i.e. AEM 50-1200 full time, with dual Walbro F90000267 on demand)
Fitment Specs
SPECIFICATIONS:
FITMENT:
Nissan GT-R R35
SPECIFICATIONS:
PM the price please
1 - 5 of 5 Posts
