I picked up a 17 FBO 30k mile R35 a few weeks back and instantly noticed an oil smell when stopped.
The oil smell is brief but potent. It goes away after about 10-15 seconds. I smell it only when stopping. There is no smoke coming from the exhaust and no smell of oil out of the exhaust (had someone ride behind me).
It has plenty of power, all gauges look good on the dash. However, it does have a weird idle. Every 10 seconds or so the car will lope. It’s not really a rough idle but it’s not right. Another thing is that it’s ever so slightly sputtering only at 2500 rpm when in manual mode. Almost like it wants to change gears (trans tune maybe or spark plugs?). It’s just odd that it only happens at 2500 rpm. Since I’m listing things off, it also takes a few seconds to crank. It’s pretty grumpy (even when priming the fuel pumps first).
Mods:
ID 1300 injectors
Fuel pumps unknown
speed density tune
Cobb intake-inlet
Cat back
Catless downpipes
E85 kit from Cobb
I’ve checked all around the engine, drain plug, oil cap, exhaust, downpipes no signs of oil. Oil level is good.
I did see what I think is an oil line which has a coupling with a possible leak. It’s located right in front of the engine below the radiator. (See photo).
Do guys have an idea of what could be the issue?
I’m a noob and learning as much as I can about this car. But based on my limited knowledge, my suspicion is it’s a bad turbo seal causing the smell.
Mods:
ID 1300 injectors
Fuel pumps unknown
speed density tune
Cobb intake-inlet
Cat back
Catless downpipes
E85 kit from Cobb
