1 - 16 of 16 Posts
What's Included:
- Custom 2014 Nissan GTR Headlights (Pair)
- Bluetooth RGB Halo Controller & PnP Wiring Kit
- Morimoto XB D2S 6500K HID Bulbs (Pair)
- Morimoto XB D2H 6500K HID Bulbs (Pair)
- Morimoto XB35 AMP HID Ballasts (Pair)
- Morimoto HD Relay Harness
Headlight Mods:
- Quad LED Concepts Plasma ColorMorph RGB Halo Rings
- Morimoto GTR Clear Lens Swap
- Retrofitted Morimoto Bi-Xenon HID Projectors (quad HID low beams, dual HID high beams)
- Gloss Black Shrouds w/Factory Dark Metallic Grey Trim
More Info: Brand new 2014 headlights were used for the build and only installed for a couple months in the Summer. Lenses are still in very good condition. No cracks or damage to the rear housings.
Plug-n-Play Installation: Everything needed for plug-n-play installation is included in the sale (no cutting of factory wiring necessary).
Quad HID Projectors: Gives you quad HID low beams and dual HID high beams. Four Morimoto XB 6500K HID bulbs are already installed for pure white HID color instead of the factory Koito 4300K D2S HID bulbs.
RGB Halo Rings: Can be controlled via a Bluetooth controller that connects to your phone on a free app. There's endless options for different colors, strobing patterns and flashing different colors automatically. Very bright at night with 100% brightness and visible during daytime.
Installation: Very straight forward with all labeled connections to know where to plug each connector on the headlights. Full installation requires removal of the front fascia to remove the headlights, installing a relay harness, HID ballasts and RGB wiring. Both the relay harness and RGB controller have positive connections with inline fuses that run to the positive terminal on the battery.
Price: $2200 USD + shipping OBO anywhere in Canada or the lower 48 US
If Interested: Please send me a PM. Comment questions in thread.
Thanks for looking!
Nice touch, reminds me of what umnitza.com sells!
Lawerence
Thanks. Umnitza has some great halos as well, these are LED Concepts ColorMorph RGB halo rings with their Bluetooth RGB controller.
As far as I'm aware this is the only set built like this, using quad RGB halo rings and 3" HID projectors to fill up the whole high beam shroud hasn't been done before.
· R35 member
Can you send me some close up pics of the lenses? Any moisture in them? Scuffs, scratches, or dead bugs ? Interested , as they would look good on my blue car.
Ok. couple dumb questions. Realize my car is not near me. Its far away in a shop right now.
My OEM 2009 headlights, vs. these. I understand the difference in the lights themselves. Trying to understand the general look of the housings, etc. You mention gloss black housing. Is that inside the lens. In other words, will these look much darker than my OEM lights? I have a dark car and would like to move to a darker, more "smoked" look in general. Hard to explain. I understand the lens is not smoked.
Discussion Starter · #11 ·
Lens is not smoked as that compromises your light output. All the chrome pieces and shrouds in the headlight are painted gloss black. So it has a blacked out look, but not a tinted lens.
Grille Hood Automotive tire Automotive lighting Bumper
1 - 16 of 16 Posts
