For sale: Used/damaged Rexpeed carbon fiber front splitter - $275 shipped - Cincinnati
This is the M-Style Carbon Fiber Splitter from Rexpeed, which sells new for $870, not including overseas shipping.
- Twill weave carbon fiber
- Gloss clear coat finish
- About half the weight of the factory splitter
- Fits 2008-2011 models only
I damaged this splitter at Mid-Ohio a couple years ago, and I was thinking of throwing it out, but if you or a friend are handy with fiberglass or carbon fiber repair, this might be a good project.
The face of the splitter is fine (except for normal wear and tear, such as stone dings in the clear coat). The damage is to the underside, where I made some quick repairs to get through the rest of the weekend at Mid-Ohio:
• One of the tabs that slides into the engine cover is gone; the other tab was damaged so I riveted and hot-glued it for support.
• The holes for the two 10mm bolts below the radiator support were damaged, and I patched those up with the hot glue gun.
• The right side was dragging on the track on my way back to the pits and was ground down, leaving a hole.
I'm asking $275 total, so that includes shipping via UPS Ground. If you live in/near Cincinnati and want to pick it up, then it'll only set you back $100.
I accept PayPal, or I'll take cash if you pick it up.
