Hey Nagtroc!
I have some lightly used Forge Motorsport actuators for GT-R. They were on a street driven car for less than 4000 miles. They are in good condition with only slight signs of use. They have the blue spring installed, and other springs are available through Forge. The Blue spring, when used with the GT-R stock turbo result in about 13-14psi base boost pressure. If aftermarket turbos are used, we usually see about 15-16psi base boost pressure. These actuators are a must for those looking for very high and sustainable boost levels over the entire power band.
Designed by Forge to replace the original component this uprated actuator is serviceable and guaranteed for life. This product is built with a predetermined actuator spring suitable for at or slightly above factory boost levels.
Manufactured from Billet Aluminum and Laser cut stainless steel brackets ensure OEM like fitment and performance.
The actuator can be assembled with a stiffer spring upon request. Please contact us directly concerning this process.
$385 Shipped!
$385 Shipped!
