Compression is just that. It holds the max pressure attained when cranking. There's a one way valve.
Leak down is a constant pressure test, where the leakage is given as a %.
They both give you info on gas tightness of the cylinder, but the leak down enables you to determine where it's leaking.
Inlet valve - blowing at the throttle body.
Exhaust valve - blowing at the tail pipe.
Piston rings - blowing out the dipstick or oil filler.
Head gasket - bubbles in the coolant or crank case pressure.
