wondering if anyone has any feed back on them ..
http://www.girodisc.com/Girodisc-Front-2-piece-rotors-for-Nissan-GT-R_p_6319.html
from what i can remember they do have great reviews on other cars.Our rotors are made for the 09-11 GTR. Unfortunately, we don't have any test data for you but our rotors really do speak for themselves. Feel free to do reviews on any online forum out there that we make parts for (our most popular being Evo, STi, & Porsche) and you will see that our products go above and beyond the competitors like AP racing, etc. Our hats are 100% made in the USA and use hardware that fully floats the rotor as opposed to many competitors bolted 2-piece designs. Our rotors are designed to withstand the highest temps possible and we have many guys running these on full race applications including Ferrari Challenge cars.
Let me know if there are any other questions I can answer for you. We'd love to get everyone in the GTR world on-board with our rotors… we can assure you that you'll be more than satisfied with what we offer. Thanks!
What is the thickness of the titanium pad shields? Do they wear out with regular track heating cycles like stainless pad shields do, or are they a permanent solution? I have found that stainless pad shields do not last as long as I would have thought before they become brittle.it will help to reduce the temperature around the piston/boots/seals area and won't diminish clearance for the pads
I'm curious to see the reports on these rotors, as I think I'll need to replace the OEMs on the 09 soon.Seems like an interesting solution. Roughly the same price as the J-hooks but come with a new hat and are much lighter weight (I believe the J-hooks are heavier or same weight as OE?)
We haven't tested them yet on a GT-R. However, I have those in a Evo X. Had several track days and daily driving on them, they work pretty well just like shims supposed to do. I will contact GiroDisc and see if they have actual data for the shims.What is the thickness of the titanium pad shields? Do they wear out with regular track heating cycles like stainless pad shields do, or are they a permanent solution? I have found that stainless pad shields do not last as long as I would have thought before they become brittle.
When it comes to "Stock' or "Direct" replacement, the parts are supposed to be dimensionally identical to the stock, except some welcome improvement such as increasing rotor thickness e.g. to 34mm vs. OE's 32.6 for 2012 rotor and reduce the diameter just enough to eliminate the undesirable rusty lips on the rotor edge provided these improvement are incorporated w/o affecting its matching components such as rotor hat or brake pads.I just noticed on GiroDiscs website they say:
The Girodisc system is a direct replacement for the OE disc when used with a any 62mm or shorter brake pad made for the Brembo type M caliper. The factory pad height is 66mm and will NOT work with this rotor. We do this for two reasons, first and foremost the pad prices of the shorter pads are significantly less than the OEM size pads. The Ferodo DS2500 pads that we sell for this application are 59mm and $120 less than the 66mm versions, a significant savings we'd like to pass along to our customers. Secondly the larger hat and smaller rotor anulus result in a lighter overall rotor with zero drawbacks in braking performance.
Does this mean there is less pad material making contact with the rotor? If so, wouldn't this reducing braking performance?
+1 to this. I would think a smaller connection surface between the pad and rotor will result in poor heat dispersion. The GTR has a hard time managing heat with the larger 66mm pad+rotor contact patch. I would not recommend making them smaller in an effort to save weight. At least not for a tracked GTR.I just noticed on GiroDiscs website they say:
