sounds good!
What was your install time for both?Yap upgraded to id1000 at the same time, Jack will take care of it!
I'm doing the same thing next week after I pick up my car from Shep. I see in the instructions it says to update your tune BEFORE installing. I am assuming it is OK to do some 3rd gear pulls for Jack with the new injectors and 3" intakes after install so Jack can dial in. Assuming you don't track or drive to hard. Can you describe your tuning process with Jack?Yap upgraded to id1000 at the same time, Jack will take care of it!
What Jack is going to do (speaking for him) is initially give you a "ballpark" tune so you can go out and datalog.I'm doing the same thing next week after I pick up my car from Shep. I see in the instructions it says to update your tune BEFORE installing. I am assuming it is OK to do some 3rd gear pulls for Jack with the new injectors and 3" intakes after install so Jack can dial in. Assuming you don't track or drive to hard. Can you describe your tuning process with Jack?
You need a tune, because its a 3" intake.Where can I get this intake?
When you are tune ready you can get the intake from me. Here is a thread for you to look at. http://www.nagtroc.org/forums/index.php?/topic/60428-gotboost-3-intakes-now-available/Where can I get this intake?
