1 - 20 of 956 Posts
I decided it was time to step it up a notch, and produce an engine package with utmost quality and performance in mind while trying to keep the GT-R tax at a minimum. Follow me as I build my car with a package that we will soon offer when everything is to my liking. I have chosen some of the best parts in the industry for this build, along with many of the products we currently produce and a few that we will be releasing soon.
This particular package will be called the GBP 900 package and should easily produce around 800+whp on E85 when finished.
Also John Shepherd from Shep Trans will be providing me a STAGE II.5 GT-R trans upgrade.
The build will consist of:
Pistons: CP Carillo w/ coated skirts
Rods: Carillo
Cams: Tomei 256/264
Headstuds: Nissan stock oem
Heads: Blended and polished ports by [email protected]
Headgaskets: Stock oem
Valve Springs: Kelford single springs
Oil Pump: Stock oem
Turbos: GTX Hybrid by SIR
Actuators: Forge
Inlet pipes: Gotboost Performance custom 2.5" to 3.0" with heat barrier wrap
FMIC: AMS
I/C Piping Kit: 3" Gotboost Performance upper and lower piping
Intakes: 3" Gotboost Performance with MAF delete
Throttle Bodies: Modified oem
Blow Off Valves: Tial Q
Injectors: Injector Dynamics ID 2000's
Fuel Rails/ Regulator : AMS/ Fuel Lab
Fuel Pumps: 3 pump system by Tony @ T1Race
Downpipes: AMS non-catted ceramic coated black
Midpipe: Gotboost Performance non-catted
Rear Section: T1R stainless
Engine Control: Cobb AP 006 w/ Gotboost Performance SD Conversion Kit
Coolant overflow: Gotboost Performance custom tank
Tranny Cooling: 2012 spec trans cooling
Tuning: Tim Bailey
Trans Upgrade Stage 3 by John @ Shep Trans:
PPG 1st gear set
Dodson Sportsman clutch
Dodson FWD retainer
Dodson Mechanical lock #1
Dodson Mechanical lock #2
Selector Piston Shims
O-ring and seal upgrade kit
Oil pump shaft upgrade with blueprint
6 neodymium magnets
High temp rear differential oil seal
Stainless re-usable internal filter
Transmission brace by Gotboost Performance
How about a package with all the bolt ons packaged together for the stock engine guys.
Discussion Starter · #15 ·
Good stuff Dave, good selection of parts.
Might I suggest options for WPC treatment on certain parts and DLC application to the crank.
What about posting options?
Haha Shiv,
I was goiung to do that as NickTO recommended the WPC treatment also.
Discussion Starter · #16 ·
my wife is going hate you dave, cuz i'm going to want this ;)
No need to worry, just have her talk to my wife and Bev will calm her down..lol.
Excellent !
Looking forward to the results.
Tokyo Nightmare
Subscribed!
In for a non GTR taxed upgrade package !
1 - 20 of 956 Posts
