Wanted to post up a quick overview of the install on the Gotboost Performance flex fuel kit for those looking to install it themselves. Dave also provides an excellent install guide for his product.
Basically undo the return line that goes to the back of the intake manifold and replace it with his that has the bolts and is pre-lubed for easy install. The intake manifold DOES NOT have to be removed for this.
Next, remove the factory support of the fuel line on the firewall. The bushings for this are used as spacers for the GotBoost mounting bracket with heat shield.
Next use the supplied fitting on the metal return line to attach to the flex sensor.
Plug the brown connector into the flex fuel sensor and run the harness threw the grommet and plug into the air pump connector.
Run the flex smart cable into the interior via the grommet behind the battery. The battery will have to be removed to access the grommet. Install the LED in the interior where its readily visible.
The install is very simple and can easily be done with very little tools. Any questions just email Dave, he gets back to people right away.
