1 - 20 of 32 Posts
Founder/Admin
***EDIT I will take over this thread and keep it updated if people wish to report 1/8th times - Wicked***
Owner/driver must be a NAGTROC member.
Time Slip and or video required
Run must be made at actual 1/8th mile drag strip using that facility's timing equipment
Please submit your run in the correct format with proof to be added to the ranking
Unlimited
#1 ( Owner: George Dodworth, sevenspeed @lasergeorge )
4.466 at 170.88 MPH -- T1 Race Development Build 2009 R35
1.163 60'
3.8L Stock Cast Block, ETS Pro2100 Stock Location 76mm, Small Tire
Shep Stage 6+ -- 15" M/T -- MoTec M1 tuned by Tony Palo at T1 Race Development
11/03/2019 at Maryland International Raceway - World Cup Finals
Modified Turbos
#1 kk09gtr (SVM)
1.3913 60' (Syvecs) 1/8th = 5.7403 @ 127.22mph
SVM built engine, Syvecs tuned, 17in Hoosiers,
10/26/13 @ Santa Pod Raceway
OE Turbos
#1 sleepdoc
1.456 60' (Cobb) 1/8th = 6.409 @ 108.25mph
3/11/11 @ PBIR
Under Warranty | OE ECU + Tires
#1 sleepdoc 100% Stock
1.688 60' 1/8th = 7.331 @ 95.09
11/??/11 @ PBIR
Under Warranty | OE ECU + Tires (DBA-R35 2012+)
#1 MC
1.56 60' 1/8th = 6.85 @ 101.4
2015 GTR NISMO
12/10/2015 @ Farmington Dragway Mocksville, NC
Edit. DId not follow directions the 1st time.
Here is a slip from my local 1/8 mile, Its still my best 1/8 mile by a few hundredths, I think another board member or 2 was their that night. 7/29/11
I think I am number 3 for the stock turbo boys. Sleepdoc and Marc being 1 and 2.
OE Turbos
#3
BigBill 6.558 @ 105.8 MPH
1.48 60' NIS006
July 29th 2011 Countyline Dragway Miami FL
MC, the 1/4 mile rankings are months old. Can we get an update?
Quick question why does it half to be at a 1/8 mile track?? It's not like your backing off at the end of the 1/8 vs the end of the 1/4.
Good question, I was wondering the same thing. Do we list our 1/8 stats if done as part of a 1/4 run ?
Banned
I'm pretty sure timeslips showing 1/8th mile ETs from a 1/4 mile dragstrip will be accepted. MC is just saying it has to be from an actual dragstrip so no Gtech/driftbox/etc runs will be accepted. Anyway here's mine:
OE Turbos
#2 CornedOutVR38 6.445 sec @ 112.50 mph
1.513 60' (LC4)
11/19/2011 Island Dragway Great Meadows NJ
I'll post the slip tomorrow.
Okay, Here are mine:
OE Turbo:
sleepdoc 6.409 sec @108.25 mph
1.456 60' NIS 006
Mar 11 2011 PBIR
Under Warranty OE ECU and Tires
sleepdoc 100% Stock
7.331 sec @ 95.09 mph
1.688 60' LC2
Nov 2011 PBIR
Banned
unlimited
6.12 @ 125 low boost 1.69 60ft.
I did have a better run ([email protected] )but do not have any video of it and can not find the slip.
7.543 @ 96.9 MPH
1.918 60'
Summer 2011...Low 80's F, Countyline Dragway Miami FL
Midpipe + Cobb AP Nis005 stage 2 15 psi, S/C/N Auto...
I know that is possible to go faster with this car but I'm more for looks than performance ;-)
OE Turbos
#3
1.48 60' NIS006
Is this with LC4? I don't think LC2 has it in it....
This was Cobb 3750RPM LC2. On my car it goes to about 4000 rpms, I let off at about 3800rpms. That was on Nitto 18" Drag Radials.
My best is now from PBIR I went 6.49 at 107.6mph. That was on M&H Drag Radials and HP Logic Cobb LC2 map. On that run the 1/4 mile traps did not work, just my luck.
Here is my 1/8 mile time slip at Firebird raceway in the Phoenix area.
2012 100% stock, warranty, stock everything including tires, pump gas.
NOTE: I had to let off at the 1/8th mile so as not to break the 11.5 sec rule and get booted on my first run!
SVM
Hi Guys..Just to let you know My personal R35 nicked named "Gundam" on the 27/10/2013 Ran his best 1/8th Mile @ Santa pod in the UK
Can you include his time in Your data list. (OEM modified turbos on Stock manifolds)
Hear is the actual printout... as you can see the 1/8th is up in 5.7403 secs @127.22mph WR OEM Modified Turbos
Unfortunately the Syvec's cut the management and held the car at a steady 127mph to cross the line.
Best 1/4m to date has been 9.03 @155mph The Run above was an attempt on the Quarter WR.....Next Time Lol
Can I just add My car is full weight Including All Trim (except passenger seat) + the addition of a Full Roll Cage) The car is Road legal
however we did change the rear tyres to 17" Slicks
Regards
KK
1 - 20 of 32 Posts
