1 - 20 of 471 Posts
R35 GT-R
OK I've decided to tackle these drag list threads. This is now up to date.
*edit by Wicked
This list is for GTRs only. If you'd like to have a time added to the list, from now on post your file here in this thread or post a pic of it as I do not have access to the previous email addy. Also include a list of modifications. Your post must include the results posted in the same format that is used in the list to be updated.
This list is for GTRs only. If you'd like to have a time added to the list, email the raw, unedited .dbn (Performance box or Drift Box) or .vbo (V-Box) file to [email protected] Also include a list of modifications.
Only GPS based computer/accelerometer times from Performance Box, Drift Box, or V-Box equipment and the new Dragy Performance Box will be accepted for this list. No extrapolated times from 1/4 mile time-slips. All submitted data must be reviewed for accuracy and approved before it will be listed. The maximum allowed downhill slope over the course of the run is 3.00%. Any run that exceeds 3.00% will not be added.
When comparing the below numbers, please keep in mind that variances in temperature, humidity, road surface conditions, tire grip, type of dynamometer used, and driver input can all have a measurable impact on the data.
60 -130 mph (96.5-209.2 kph):
1.59 - George Dodworth, T1 Race Development, ETS PRO2600 (76mm) Stock location turbos, MoTec M1 tuned by Tony Palo (strip)
2.28 - ETS Super 99 (strip)
2.40 - Jan on Prime R Motec tuned by TSM, E85
2.67 - AMS Alpha-Omega, Syvecs SGTR, C16 (strip)
2.74 - Crazyrc on ETS 6466, E85, Jack's Built and Tuned on Ecutek (strip)
2.78 - ETS 6466's, E85, Cobb (strip)
2.91 - Shep, AMS Alpha-16, Syvecs SGTR, E85 (strip)
2.96 - Chris SBD / Visconti Tuned / E85 / Tim Lynch 3.8L / Gen 3 SBD1400R Turbo Kit/ 1500whp / Shep 1K / 4050 lbs (strip)
3.20 - WhitLightning TSM Elie Plus, E85 (strip)
3.22 - changster aka battle60130/ TSM Alpha 12 (street)
3.27 - GtrHeritage aka Tim/ T1 built FP9568, E85, 100+ heat index (street)
3.27 - turbotuner20v TSM 3.8L + TSM Elite PrimeR turbos/ TSM tuned w/ Cobb ECU/Ecutek TCU on E85 (street)
3.28 -SpeedByDesign Chris, Gen 2 SBD1400R Turbo Kit
3.31 - AMS Alpha 12, C16 (strip)
3.33 - Divexxtreme / Switzer R1K-X, Q16 (strip)
3.36 - Topspeed Motorsports / Alpha 12, Cobb AP, C16 (street)
3.39 - Droptopp TSM 4.1 with Elite Prime on E78 (street)
3.46 - Heacuva / AMS Alpha 12, MS109 (street)
3.47 - Celsius Prime turbos tuned by TSM, E85
3.57 - RicardoGtr - Built 3.8 / E85 and Meth / GTX3584RS @ 42 psi / 1,300whp / full weight on street tires (strip) Puerto Rico)
3.58 - timsanders / AMS Alpha 12 (strip)
3.60 - booztd 3 SBD1400R Turbos, (strip)
3.60 - Chris Riggs, SBD1400R Gen 1 Turbo Kit E85 (strip)
3.63 - xwing ETS Pro1400 E77, 4.1L, 35psi, 20" wheels R888 tires, 4100lb with driver (Street)
3.64 - Divexxtreme / Switzer Flex-Fuel Ultimate Street Edition, E85 (strip)
3.68 - Droptopp / STM (36lbs boost) E70 (street)
3.70 - Divexxtreme / Switzer Flex-Fuel Ultimate Street Edition, E85 (street)
3.70 - Topspeed Motorsports / ETS kit, C16 (street)
3.71 - Topend / FP HTA86 (street)
3.74 - Celsuis TSM Primes E85 (street)
3.77 - jm-imports/JUN R1,ETS3586 (strip)
3.78 - Formidable ETS Pro1700, Motec Street 20 inch tires MPSS (street)
3.81 - Schred86, Built 3.8,Hks gt 1000, Ecutek tuned by ivey, E85/ 18 m&h racemasters front and rear Street (street)
3.82 - franzecars, ETS3582R, E85 (street)
3.82 - Dammit_Dan - E85 / Ivey Tuned / Ivey 3.8 Stage 1 engine / IT1050x / 1100whp / Ivey 1G trans / Full Weight /(street)
3.83 - mikewads / AMS Alpha 10, E85 (street)
3.84 - david buschur slicks. BR160 package. (strip)
3.85 - Switzer R1K, Q16 (street)
3.89 - vtknight / Switzer R1k, Q16 (strip)
3.92 - Switzer USE Flex-Fuel E85 (strip)
4.00 - TeKiZeRo Omega 12 turbos Built 3.8, Shep OneK, E85 on R888R (street)
4.10 - Exelixis Motorsport, C16 (street)
4.17 - Scuba_Steve SIR Stage 3 (strip)
4.18- franzcars 4.1 GTX3582r gen1 (street)
4.24 - Lambo Joe Alpha 9+ turbos/Shep 1K E85
4.27 - LTHL VHM T1 30r's (street)
4.28 - Vacuumsauce / GT30 E85 (street)
4.34 - Divexxtreme / Switzer Ultimate Street Edition, 93 octane (street)
4.37 - Droptopp Alpha 9 built by STM
4.39 - VEGASGTR / (street)
4.45 - Bob / AAM GT900R, E85 (street)
4.48 - pepinozaur Ben Linney gt30 turbos fuel 93oct + 100%meth
4.55 - gripforce-gtr (street)
4.58 - TeKiZeRo AMS-spec 3.8 w/ Alpha 9+ E85 (street)
4.59 - droptopp/ STM built Alpha 9 (street)
4.65 - likeaboss GT28 (2871), E85, (street)
4.68 - turbo50mike / SIR Stage 2 Turbos, Ivey built/tuned e85 (street)
4.70 - Kisco / Switzer E900 (street)
4.82 - Ben Linney GTC / Spec 800, E85 (street)
4.91 - E85 / Ivey Tuned / stock engine / BL1050x / 800whp / Ivey 1G trans / Full Weight w/ 310lb Driver (street)
4.92 - Wicked / Spectrum Motorsport GTX2867 e77 (strip)
4.96 - Gapzila / BL750x gen 1,e85 , alpha bottom end stock heads, BL fmic with piping,tuned by Tim Bailey (street)
5.07 - Goonthree FullBlown GTX2867 (street)
5.13 - JD223 Stock Motor/Trans GTX30r turbos , FBO, E85. (street)
5.33 - [email protected] Ucp750 package e85 (strip)
5.37 - 2highpsi Nismo Turbo, built motor with stock trans e85 (strip)
5.37 - Dammit_Dan / Ivey Tuned / stock engine / BL 1050x / 800whp / Ivey 1.5 trans / e85 / (street)
5.38 - Lofvis / Alpha 9, Built engine E85 (street)
5.39 - Booooh / SVM 950 / 93 octane (street)
5.48 - Audioenvy / SIR Stage 1 turbo, bolt-ons, E85 (street)
5.62 - 1Spec / SJL Hybrid Turbos, stock motor and trans, E85 (street)
5.85 - Mike at AWD Motorsports / full bolt-ons, *stock turbos*, E85 (strip)
5.92 - IMFASTER / AMS Alpha 9, built-motor, 93 octane (street)
5.99 - Divexxtreme / Switzer P700, 100 octane (street)
6.00 - Switzer P800, 93 octane (street)
6.22 - Goonthree / GTC intake, mid-pipe, DP, cat-back, E85 tune (street)
6.36 - TheHitman / SIR Stage 1 turbos, built engine, 93 octane (street)
6.45 - mr2slo4u / Cobb intakes, 2012 inlets, SIR pumps, mid-pipe, DP, cat-back, E85 tune (street)
6.46 - Dammit_Dan / FBO E85 / Ivey Tuned / stock engine / stock turbo / HKS actuators / (strip)
6.56 - Pizzamangtr / catless DPs & MP, exhaust, intakes, injectors, inlet pipes, pumps, Visconti tune/E85 (street)
6.57 - Easy2speed / TopSpeed Tune, HKS Midpipe, AMS Downpipes, E85 (street)
6.60 - Divexxtreme / Switzer P700, 93 octane (street)
6.61 - Dana @ Virtual Works / bolt-ons, stock turbos, E85 (street)
6.69 - PianoProdigy / Stock turbo, FBO, E85 (strip)
6.77 - LordKevin Stock Turboe, E85 (street)
7.05 - Divexxtreme / Switzer P600, cat-back, drop-in filters, 100 octane (street)
7.10 - awdtt/SIR Tuned stock turbos,FBO E73 (street)
7.16 - JimmyP / E85, stock turbos, intake, exhaust, injectors, GTC tune (strip)
7.22 - Easy2Speed / TopSpeed Tune, HKS Midpipe, AMS Downpipes, 93 octane (street)
7.23 - Tom C / AAM DPs, MP, T1R cat-back, AAM 2.75" Intakes, inlets, 1000cc Injectors, AAM tune 93 octane (street)
7.27 - FikseGTS / 2013 with midpipe and tune / 93 octane (street)
7.74 - HoustonT / Boost Logic BL640 (downpipes, y-pipe, BC, hard IC pipes, tune) 93 octane (strip)
8.62 - MC/ stock 2015 GTR 93 octane(strip)
9.4x - FikseGTS / stock 2012 / 93 octane (street)
9.99 - Divexxtreme / stock 2010 / 93 octane (street)
For the sake of comparison, here are some 60-130 times for some other vehicles:
3.04 - Underground Racing TT Gallardo E-Gear (Bob Helms' car) / 1-shift
3.31 - AMS Alpha 12 GT-R
3.33 - Divexxtreme / Switzer R1KX GT-R
3.53 - Underground Racing TT Gallardo Nera 6-MT / 2-shifts
3.61 - HoustonT / Underground Racing TT Gallardo 6-MT / 1-shift
3.85 - Switzer / R1K GT-R / 2-shifts
3.95 - 1swtride / C6 Z06 / built 427, YSI blower, 1080rwhp, auto
4.09 - Acicchelli / TT Gallardo / 1-shift
4.21 - DJborya / BMW 325i / S52 with 80mm turbo / 1-shift
4.23 - TwinTurboM3 / TT E46 M3 with nitrous / 0-shifts (4th gear only)
4.49 - TwinTurboM3 / TT E36 M3/ 0-shifts
4.52 - jbsteven / SC&TT Ford GT 994 rwhp / 1-shift
4.53 - HoustonT / 880 rwhp Supra / 1-shift
4.55 - Greg-TT / 770awhp GT-R
4.70 - SCvette00 / Switzer E900 GT-R / 824 awhp
4.87 - Oz / Supra / 1-shift
4.88 - 1SwtRide / C6 Z06 / 1,080rwhp
5.14 - Hllywood / TT Viper / 93 octane/ 2-shifts
5.24 - Blacksheep / Supercharged '08 Z51 Corvette, Dallas Performance 1000: Forged 416, ProCharger F1C @ 18psi, Alky Control Methanol 942whp/938tq, 0-shifts
5.27 - Lil Powell / C5 Vette with big motor and NOS
5.51 - FiskeGTS / Heffner bolt-on TT800 Gallardo
5.61 - RaceMX-M3 / Turbocharged E46 M3 / 1-shift
5.74 - Divexxtreme / Supercharged C6 Z06 / 1-shift
6.23 - MikeWads / E92 M3 DCT with ESS SC and 100 shot of nitrous
6.36 - Jmoney / Supercharged E92 M3 11 psi, 1-shift
6.59 - Dads C63 / Bolt-On C63 AMG + 125 shot of Nitrous
6.65 - Acicchelli / Renntech SLR
6.73 - FikseGTS / Ford GT with pulley and Heffner tune
6.80 - DLSJ5 / ESS SC'd E92 M3 DCT / 3-shifts
6.85 - gringointegra / TC'd Acura Integra, 1-shift
6.89 - Vrybad / C5 Z06TT (APS Turbo, no cats, stock muffler, 573 rwhp @ 9.5 psi) / 1-shift
6.95 - hotrod182 / 335i w/ JB3 piggyback ECU and Nitrous / 2-shifts
7.05 - Divexxtreme / 2010 GT-R, Switzer cat-back, drop-in air filters and Switzer 100 octane tune, peak boost 18 psi
7.24 - Acicchelli / Stock SLR
7.48 - Acicchelli / Renntech SL65 AMG
7.52 - IMG / E90 M3 / ESS VT625 Supercharged
7.58 - PencilGeek / E92 M3 6-MT, RD Sport RS-46 "Stroker" motor and ESS Tuning S/C (6.25psi)
7.59 - Blacksheep / C6 Corvette Z51 (heads/cam, 484 rwhp) / 2-shifts
7.60 - Easy2Speed / GT-R / downpipe, mid-pipe and tune
7.71 - TMC CL65, '09 CTS-V with 8.6" pulley, CAI, LS7 ported TB, headers w/ cats, heat exchanger
7.74 - HoustonT / GT-R / 640 HP (downpipes, y-pipe, BC, hard IC pipes, custom tune)
7.85 - Acicchelli / Stock LP640 / 2-shifts
7.86 - Divexxtreme / Stock C6 Z06 / 2-shifts
7.95 - Byzantine / '06 Gallardo 6-MT, catless exhaust & 105lb weight reduction, 2-shifts
8.04 - JHDavis / SL65 with tune
8.08 - Dads C63 / Bolt-On C63 AMG
8.16 - 930chas / E55 AMG
8.25 - Dodger63 / C63 MHP headers, tune, intake, scoops, DRs and skinnies, race fuel
8.24 - DrivenAgain / CL600 AMG
8.28 - KeithTA, Panamera TT with ecu flash
8.31 - biglare / SC'd E90 M3 DCT / 2-shifts
8.40 - bassn_07, E5 with full bolt-ons
8.45 - TMC CL65 / '09 GT-R, mid-pipe, tune
8.45 - TMC CL65 / Kleeman CL65
8.59 - Dr Jitsu / Supercharged M3 / 1-shift
8.67 - DLSJ5 / Supercharged E46 M3 SMG / 2-shifts
8.89 - MTHIS / C63 with LTs, filters and tune
8.95 - sammyrusso / Supercharged E92 M3 DCT / 3 shifts
9.12 - Peshki19 / EVO IX / bolt-ons, pump/meth, 2-shifts
9.15 - Mr. 5 / 335i Sedan with GIAC flash and EBC, 1-shift
9.4x - FikseGTS / stock 2012 GT-R
9.42 - Easy2Speed / stock 2010 CTS-V / 1-shift
9.47 - 02avantimola / Audi S4 Stage 3 on E85
9.58 - [email protected] / B5 S4 on MS109 / 2-shifts
9.62 - M6koo / M6 SMG (intake, exhaust, pulley, tune) / 2-shifts
9.79 - sammyrusso / stock C63 with P31 package
9.92 - Byzantine / '06 Gallardo 6-MT, 2-shifts
9.99 - Divexxtreme / stock 2010 GT-R
10.13- Acicchelli / Stock F430 / 3-shifts
10.18 - madsex343 / E92 M3 DCT with exhaust, filter and tune
10.71- DLSJ5 / Bolt-On E92 M3 DCT / 3-shifts
10.72- Acicchelli / Cayenne Turbo S GT700
10.87 - Apexit1 / Audi B8 S4 / intake,exhaust,tune,pulley, 6-MT
10.93- Acicchelli / Stock Mercedes E63 / Auto
10.97- WK446 / Nissan GT-R with updated Launch Control firmware
11.81- HoustonT / Stock Lexus IS-F / Sequential
12.42 - TheCPE / 2012 Mustang GT with mid-pipe and tune
13.77- Acicchelli / Bentley GTC / Auto
14.05 - TheCPE / stock 2012 Mustang GT
14.36- ttboost / Stock Audi RS6
14.39- Acicchelli / Stock Mercedes ML63 / Auto
R35 GT-R
Here the graphs for AMS, timsanders, Switzer, R1k and gripforce-gtr:
R35 GT-R
Here are the graphs for Kisco, Divexxtreme's P600, and Easy2Speed:
R35 GT-R
Here are the graphs for HoustonT BL640 and Divexxtreme's stock 2010:
Good job Scott ! I'll get some numbers in the fall...I think Ill prob be in the 4.8s..
R35 GT-R
Thank you for the information as it provide us with a good comparison. I guess I should have read the content as it stated the slope of the course!
Thank you Scott for taking time to post a GTR 60-130 list.
I'm glad to see I made top 5 and I hope it stays that way for a while... LOL
R35 GT-R
Discussion Starter · #15 ·
New street car record! AMS Alpha-12 went 3.34 on DRs!!
It looks like that TT Viper is owned now! But there should be street cars that have run 60-130 in under 3.34 seconds..... or not?
R35 GT-R
Discussion Starter · #17 ·
Sure. They've just never been verified.
R35 GT-R
Discussion Starter · #18 ·
Switzer R1KX, 3.33 on a 0.1% decline.
R35 GT-R
Discussion Starter · #19 ·
Alpha-12, 3.31.
1 - 20 of 471 Posts
