BS, call hawk performance and they will get it straight. I spoke with Justin at Hawk and he confirmed wrong size. With the wrong size pad, you rotor will wear different and will not allow you to use the correct size pads later. Pm me if you need more help,
See below from other vendor:
We spoke to Justin and confirmed that the information we had from out
2010 catalog is incorrect on your application. We are in the process of
generating an RMA number and return label for first set of pads.
someone else must be having the same problem?
Stillen say they are a little shorter then factory and it won't harm the rotors.
I don't like it aesthetically.
