1 - 5 of 5 Posts
I received my dry carbon fiber hood style #2 in gloss finish from the group buy and overall the quality is great!
However, when I tried to mount it this evening the mounting holes did not align properly with the OEM hood brackets and when I applied pressure to align the bolts it resulted in the hood being misaligned. When I remove the lower bracket bolts on both sides I can see that the holes in the hood are off by a couple mm which is most likely causing the hood to torque to one side.
I guess I could drill out the holes in the oem brackets to better align with the holes in the hood but I am reluctant to do so as it would then make it harder to align my oem hood back.
Anyone have thoughts, recommendations?
Thanks in advance!
send it back?? Cant be a quality part if the alignment is off
ACG Automotive
That's too bad because that hood looks incredibly sick.
I really want to see what it would look like painted white with the carbon in the vents exposed.
^Thats the plan to color match and leave the vent fins exposed gloss carbon . . . once I can mount the hood!
ACG Automotive
SUB'D!
1 - 5 of 5 Posts
