Well I finished the intercooler install. I shut the hood and now one side will not release. I must need to realign lock.
BUT NOW, HOW DO I OPEN THE HOOD!!!
Short answer- God Speed, you are in for a terrible time. The cable has likely come off.
Long answer- You can't just pry on it as suggested. The actual locking mechanism has major anti-thefts built into it.
If you get the grill off (you will see the tabs, those just need to be pushed back with plastic or Popsicle sticks, at least you get a treat if you choose this method)
Once off, you will see these for your latches-
Access which one is not releasing, drivers or passenger side- the release is on the right side of the latch(when looking forward) These pictures show roughly where it is
What you are trying to flip is this small release lever pointed to-
You can do this if you have really small arms and hands, otherwise something very strong but small will be required. I wish I had more advise, but we have not had to deal with this as we make sure to test every latch before closing the hood on a intercooler install. Good luck, and let us know if we can help anyway.
