In my quest to find out what my 2014 GT-R has had done to it by the previous owner, I ordered some Skura 3 inch intakes and AP with Cobb tunes from Kaizen. It has a at minimum a HKS mid pipe, but I am going to take some better pictures and send to Kaizen to see if has any other exhaust mods. Unfortunately, I can't ask the previous owner what has been done.
So, this last weekend, I went to put the intakes on and surprise, it already had Cobb 3 inch intakes. I liked the red powder coated ones anyway, so I put them on. Luckily I did as one of the Cobb's bracket was broken and was rigged using what appears to be some type of insulation tape. Anyway, that issue was resolved, but during this, I realized that it most likely also had a tune on it. Of course it did. Without knowing anymore, I decided it was best to start from scratch. So, I loaded the stock tune, then loaded the Stage 2 Big SF map. I by no means a expert, but it looks to me like its running rich, but also the duty cycle on the injectors seems low if it had stock injectors. I have an indication, on the gas door it has an X and E85 written in black, that it had an E85 tune. So, I am thinking the fuel pumps and injectors were probably upgraded.
It does not seem to want to get above 15 lbs of boost. I have tried all the boost maps and the highest it gets is 15.3. Is it possible I need to get a map update from Cobb?
Going by the duty cycle at WOT, is that a good indicator of bigger than stock injectors?
I attached a data log from the AP. I only had time to do one quick run this morning. I would appreciate any feedback on reading what this log says and helping decipher what exactly has been done to this car. Thank you.
