1 - 14 of 14 Posts
MAJJ
ALPHA 9
Hey guys, installing some BOVs soon and thought of refreshing the engine a little by replacing some of the silicone hoses.
I don't have space to remove the bumper atm, so I only want to replace the silicone hoses that I can reach with just the hood open, if i've missed any possible hose parts.. please let me know.
I need help finding the correct size I listed below + finding the right place to sell the parts. I know most sell them as a kit, I only need what i highlighted below, some in blue, some in red. Any help would be appreciated.
A: throttle body coupler size? I found options in link below but don't know what OEM size is (3"x3" or 2.75"x3 or...)
https://www.z1motorsports.com/straight-couplers/z1-motorsports/275-30-long-silicone-coupler-p-9054.html
https://www.z1motorsports.com/straight-couplers/z1-motorsports/30-long-silicone-coupler-p-4907.html
https://www.z1motorsports.com/straight-couplers/z1-motorsports/35-long-silicone-coupler-p-4908.html
B: BOV vacuum hose diameter and length? (4mm, 6mm or 8mm?) I believe the length is 1" correct?
https://www.z1motorsports.com/vacuum-hose/z1-motorsports/4mm-silicone-vacuum-hose-p-4932.html
https://www.z1motorsports.com/vacuum-hose/z1-motorsports/5mm-silicone-vacuum-hose-p-4933.html
https://www.z1motorsports.com/vacuum-hose/z1-motorsports/8mm-silicone-vacuum-hose-p-9790.html
C: coolant tank hose. I found this part that comes with a kit, i don't need all the kit part so was hoping to buy it separately. Will this reinforced hose work? .. any link to where i can get this?
https://www.z1motorsports.com/reinforced-hose/z1-motorsports/58-reinforced-silicone-hose-p-5029.html
D: Upper radiator hose. I was only able to find this part (without having to get a whole kit).
https://conceptzperformance.com/czp-silicone-upper-radiator-hose-nissan-gt-r-09-15-r35-21501-jf00a-s_p_18033.php
Sizes/parts found
Parts
Ultimately I'm looking for this look
Much much appreciated. ps: i know some might say it looks tacky, but trying it out to see how it looks..
MAJJ
ALPHA 9
ok so after a shit-ton day of researching online lol i think i managed to find all the parts,sizes needed... im only missing the bypass bov plug. found a turbosmart 29mm.
anyways here's my conclusion.. please advise if I got anything wrong. Thank you
hi do you know the correct sizing needed? thank you !
MAJJ
ALPHA 9
are you referring to the hose sizes? they're all standard OEM sizes and fit really well with the stock pipes.
Here's what I got from Concept Z, including the part #s
Font Screenshot Parallel Document Web page
Car Automotive parking light Vehicle Land vehicle Vehicle registration plate
MAJJ
ALPHA 9
Thank you for the info. Your engine bay looks awesome!! any chance do you have any r35 parts for sale ? thank you
Anytime and Thank you! Unfortunately, I’ve sold all replaced parts
i was wondering, did you ever have any issues with your cooling fans behind the radiator? i found out i may need cooling fan motors because both my fans stopped working. and i checked the fuses etc.
MAJJ
ALPHA 9
Hmm never had that happen. Not sure why that would happen.
It did happen to my 68 camaro once , fans stopped working due to a bad alternator
MAJJ
ALPHA 9
Discussion Starter · #10 ·
thank you, how hard was it to install all the new hoses ?
The throttle top pipes are easy. The hard pipes are tricky with the bumper on, and most probably you’ll end up loosening the fmic hoses with movement = boost leak
So do it with the bumper off
which ones are the hard pipes? what is fmic? thank you
1 - 14 of 14 Posts
