1 - 6 of 6 Posts
Just picked up a set of Vossen VFS-2 wheels for my 2012 GTR. I want to know what my options are on tires since there is a very limited amount of tires out there that will fit this setup. Suspension on the car is Airlift performance air suspension. So the tires will have to clear the fenders when it's all the way aired out .
Specs on the wheels are as follows:
Front: 21x10.5 offset +30
Rear: 21x12 offset +25.
Let me know what you recommend.
Thanks
Here's a pic of the wheels
stay away from the wide rears - right now you have only one tire option and that's pirelli - with the tire costing 950-1200$ each, consider running a 305R 265F - that will be a bit stretched on your wheels though. I love my 21s and the 355 rear looks bad ass, but the tire options suck... in the smaller sizes there are plenty of options.
I'm actually going to go with
285/35/21 and 325/30/21. They are a little bit taller than oem sizing
More than a bit taller than OEM.
28.9" front and 28.7" rear plus wider than OEM
Let us know if you get rubbing
with the Air ride you will most likely be one of the first to go that low with tires that wide front and rear.
1 - 6 of 6 Posts
