I just started running racing slicks in January for the first time since I got my car in 2008. The first time was at Circuit of the Americas in January then again early February. I did a total of three days and 15 sessions. The wear and performance results were pretty good. The outside of the tire wore a little more but tire temps generally were pretty even across the width of the tire are each session. Tire pressures generally were in the high 30psi range. After those three days the tires still have some tread left and will be even more usable if flipped.
FF to this past weekend. I went to Texas World Speedway, a track I know very well. I ran brand new slicks to start the event and the wear results are disappointing. I ran only three sessions on day 1 and only three on day 2. I even flipped the tires after the first day. One of the tires corded after the 6th session and the other don't look so hot.
COTA is a butter smooth track and brand new. TWS is an old track with a lot of rough spots and bumps. I also drive TWS harder because of its familiarity. Still, tire wear stunk and performance was really good only the first two sessions then dropped from there. The 4th and 5th sessions were a bit worse and the 6ths was just awful.
Also keep in mind I ran with VDC on at TWS since it is rarely needed there and almost never interferes. At COTA it was necessary to turn it off. I think perhaps I drove smoother at COTA for this reason whereas at TWS with the nannies on I could drive it without as much worry.
Lastly I did not do a initial heat cycle to break-in the tires in either event.
Any insight into this wear is appreciated. I suspect I'll be told t deal with it, but even at the very cheap price I paid the tires still cost a lot. I'd like to extend the life of these puppies...
Other notes:
Tires are 315/680-18
Square setup on 10.5" wheels
Hot pressures were 37-39 psi after a cool down lap and a few minutes to park
Ambient temps were nearly identical at both tracks
Other notes:
