just use http://tinypic.com/ and i think its the 3rd link
You can use an external host as 3tw0one_Go mentioned or you can use attachments and insert them into posts as needed. To do that, click "more reply" options, then you can select, attach and insert files using the options below the editor (below the place where you type your post).Where do you add photos????? It should be a simple option in my profile settings. Why should it take an Engineer and Web Designer to ask the question in this forum? Love the forum but absolutely hate the photo upload process.
Thanks!!!!!You can use an external host as 3tw0one_Go mentioned or you can use attachments and insert them into posts as needed. To do that, click "more reply" options, then you can select, attach and insert files using the options below the editor (below the place where you type your post).
