1 - 5 of 5 Posts
i just got my wheels freshly powdercoated and on my way home my tire pressure started dropping on my right front. The flat tire warning came on so I stopped to put some more air and drove back to my shop. Aparently they didn't seal the tire properly but they re-did it and now its fine. However the annoying flat tire warning is on my dash console and on my "tire info" setting on the MFD. I tried everything and tried reading the manual but couldn't find anything on how to re-set it. It says to take it into the dealer to reset but can you do it yourself and if so how do you do this. Please help. Thanks.
If you have a Cobb AP then just reset the ECU.
The Cobb AP can clear this code. I think I told it to clear all codes - and it went away. Happened to me almost every track day in the summer months.
The TPMS for the drivers side rear on my gt-r 'sometimes' reported I had a flat (0 psi) when actually the tire pressure was fine. Always happened about 3/4 way through a 30 minute track session. I suppose it was heat related because it started working again once it cooled down. I then had to reset the code via the cobb ap and the display got happy again.....
I have track wheels now (no tpms), don't have to worry with it anymore.
-Paul
1 - 5 of 5 Posts
