We all know stock car with Midpipe can max out (log shows over 100%) stock injectors with custom tune (I did) in the summer (90 deg weather). I think the stock injectors are 570 cc, so using E85 requires 50% more fuel (14.7 requires 1 part gas 14.7 requires 1.5 part E85). So for E85, it will require 855 cc (that is injectors needed for E85 with midpipe and custom tune) and that is at 100% duty cycle. Now with downpipe, intake, 2012 intake, cool temperature, why can't it max out ID1000 cc's?
Alot of people got confused that gasoline has 114,000 BTU vs E85 81,800 BTU thus to produce same BTU, E85 requires about 30% more volume which is different from above's 50% (air fuel ratio).
I will say it is possible to max out Id1000cc's especially in 6th gear as the car richen even more. I am maxed out, but I probably have dirty fuel filters which I will be cleaning soon, but the math says it will. If there was other options, I would go bigger injectors or bump the fuel pressure. Personally I would love to stay under 85%. I am no expert in this, but if above is wrong, let me know what I did wrong.
Air Fuel 14.7 1 9.76 1 4.94 0.506 Stock GTR Injectors On E85 570 cc 855
