Hi guys
I have GTR 2017
With bl1050x turbo and short block upgraded
Fuel system is viscount stg2 with hardwire
Injectors 1300ID
Clutch 7/7 dadson with basket B only
on the fuel pump the car was running perfect on high rpm (26 psi) more or less
But when I added E85 and the percentage was 55% , the boost reached 36 psi
( note : tuner target 2.4 bar around 34 psi )
the injectors duty cycle staring sometimes drop for almost a second at high rpm ( around 5k rpm or 6k rpm ) that’s usually happen on second gear or third gear and sometimes or 5th gear as well
I was checking the log by my self and I noted that’s :
The inj duty cycle is not max out ( almost 80% or 90% )
And the fuel pressure was perfect 100%
some guys told me May be the clutches cause that’s problem
any idea about the problem mention above
regards
Faisal
I have GTR 2017
Injectors 1300ID
regards
Faisal
