Vivid Racing is pleased to announce that we now carry the full Injector Dynamics product line!
The ID2000 has set the standard for linearity and control in a large injector.
$1440
Flowing in excess of 2000cc/min at 3 bar, the ID2000 will also provide a smooth stoichiometric idle on small bore engines running E85, and it will do all this while maintaining strict linearity up to 95% duty cycle at 9000rpm. With a pressure capability of 9 bar this injector can flow as much as 3700cc/min with excellent low pulsewidth linearity, and has the broadest operating range of any injector on the market.
ID2000 for R35 GTR
Injector Dynamics injectors provide unmatched driveability! Below is a video showing a steady 750rpm idle on a Subaru STi which is running a set of Injector Dynamics ID2000 injectors. Idles just like it left the factory!
The ID1000 - An Industry Pioneer
$708
This series of innovations and "firsts" have made it the most popular injector on the market today.
From high power high boost daily drivers, to NHRA Pro Stock Motorcycles and record setting turbo road race sedans, the ID1000 set the standard and marked the beginning of a new era in fuel injector performance.
Follow the shortcut links below for specific data, or scroll down to see all data for the ID1000.
T1 R35 GTR Fuel Rail Kit
Starting at $799
As the power-making capabilities of the VR38 continue to increase, the need to provide a proper fuel delivery solution for the GTR has become a necessity. After months of research and development, designing and refining, testing and verifying, the T1 R35 GTR Fuel Rail Kits are finally available for release. So if you're looking to address your fuel system needs, our advice is to do it once, and do it right...and this will be the only solution that your GTR needs.
The T1 kit was designed to be used in conjunction with our entire line of ID fuel injectors, which will provide your GTR with the best, most accurate fuel injectors available. (Your tuner will thank you!) The injectors are available in 725cc, 850cc, 1000cc, and 2000cc sizes depending on your fueling needs. Contact Vivid Racing for guidance regarding injector sizing.
$1440
ID2000 for R35 GTR
$708
- The ID1000 was the first injector offered with full dynamic characterization providing tuners with the data they needed to do their job properly.
- The ID1000 was the first injector to be offered in dead time matched sets.
- The ID1000 was the first high impedance high flow injector available providing stock idle and drivability on engines as small as 325cc per cylinder.
- The ID1000 was the first injector offered with the now famous "Top Hat Adapter" making it plug and play in nearly any application.
Starting at $799
