Since I finally broke down and bought some new tires, I wanted to make sure that I corrected the front camber that has been killing the inside edges of the front tires after I installed my Eibach springs over 10K miles ago. I was able to squeeze 11K miles out of the fronts by flipping the tires on the front wheels, but if I did not do that I would have only made it to only about 6.5K miles.
My camber adjustment was maxed out and sitting at -2.0 degrees, which I knew would kill the front tires for my street driven GTR. I wanted to preserve the ride so I was hesitant to go with new upper control arms with heim joints. Also those these types of adjustable front arms can be quite expensive. So I was searching on the net and found these inexpensive Whiteline bushings that noted that noted that I could add +/= .5 degrees of front camber. The bushings installation was quite easy and after getting a quick check of the front alignment, I did gain the .5 deg of camber and am now sitting at -1.5 degrees. My caster increased a tad bit, but is sill in spec and the ride has not been affected as far as I can tell.
If anyone is interested, I ordered the bushings online from Speed for Sale and they shipped from SoCal and arrived at my work in NorCal in only a few days.
http://www.speedforsale.com/nissangtrparts...9.html?cPath=50
Untitled by gnakata2007, on Flickr
