Installation guide for the Laser Interceptor system
PART 1 : FRONT SENSORS AND CPU
Pre install notes
This install should take around 2-3 hours depending upon your level of diy skill and requires removal of some small parts of the sensor heads which may invalidate your LI warranty. However, I have no doubt that Cliff (the US distributor) will have no issue with this modification should a warranty claim for a defective sensor be necessary as t does not interfere with the sensors function.
Remove these outer plastic pieces with a hacksaw..
I suggest not using the supplied LI fitment brackets as they over complicate the install and add bulk to the sensors and make them less stealthy.
I always mount my jammer heads using strong adhesive tape. Here in the UK I use No-Nails Exterior Tape and I highly recommend that you try and get it delivered to the US from a UK supplier as it is very durable. My other car had LI sensors fitted 2 years ago with this tape and it is still going strong.
http://www.amazon.co.uk/Unibond-Nails-Inte...6/dp/B000Y8OLO4
An alternative product in the US is made by 3M but I have no experience of this so cannot recommend it
It makes install much, much easier if you cut off the sensors' connectors and then once your wires are in the cabin, crimp new plugs to the ends of the wires. You can do the install without doing this but obviously it is a touch harder to pull the sensor wires thru tight areas.
If you do remove the plugs, keep hold of them as they will show you which way round to crimp the wires at the end.
http://www.idealindustries.com/prodDetail.do?prodId=30-496
RJ11 6-Conductor (3 pair) Connectors.
I also used a wire grabber to help pull the wires thru the rear bumper and from the trunk into the cabin. Something like this..
http://www.sonicelectronix.com/item_7835_U...+-+Grabber.html
The sensors should be placed with the receiving bubbles outermost, as level with the road as possible, and at 90 degrees to the direct of travel i.e. not toe in or out.
Last but not least all of these picture are of fitment on a UK EDM GTR. Your US cars will be a mirror image of mine, so just run wires to the driver's side of your car and you'll be fine.
Okay, on with the show....
Mounting front heads
Open Bonnet and remove the front cooling panel by lifting up the retaining clips using a flat bladed screwdriver..
Once this is out, undo the clips below as we will be running the wires for the sensors under here..
Take each sensor, put the adhesive tape on the upper surface so that the bubbles are towards the outside and pass the cables thru the grill, pulling the remaining cable thru and into the engine bay..
The red ring shows the side pieces removed..
Once you have both heads stuck in place we will run the wires towards the driver's side and the BRAKE compartment at the top of the engine bay..
Pass the wires under the ringed brackets as they will keep the cable in place.
Once into the BRAKE compartment we want to push the wires thru a small grommet in the firewall. This grommet doesnt have a hole (in my UK GTR anyway) in it so simply use a small knife to pierce the rubber. Then attach the ends of the wires to a straightened coat hangar and push them thru the grommet and into the driver's footwell. Once pushed thru, go into the cabin and grab the wires. Remove them from the coat hangar and pull the slack into the cabin.
Outside..
Inside..
Now that you have the wires inside it's up to you where you mount the LI CPU, but I mounted mine behind the fuse panel on the outer side of the footwell. This is easily removed by unscrewing this plastic nut and pulling the panel towards the pedals..
At this point you yanks are on your own as our UK cars are wired differently so you will need to look at the USDM GTR tech pdfs which are around this forum. Use these to find 12v ACC and a GND to run to the LI.
I mounted my switch below the steering wheel, but you guys may have no room here as again your cars differ from my UK car..
I also added an external speaker and changed the internal jumpers inside the LI CPU so that the alerts come from this and not the internal speaker.
Ask Cliff to do this for you prior to delivery if this takes your fancy, and I would strongly recommend also asking him to turn off the Sunlight Interference Alert (SIA) as it is annoying!
My speaker is mounted behind the AV unit..
PART 2 : REAR SENSORS
The rear heads can be mounted using the same tape and placed above the licence plate..
The cables are run up thru the holes into which the licence plate lights fit into. These are easily removed by unclipping them and pulling downwards..
Now at this point you have 2 options. You can either run the wires ghetto style up and into the trunk by placing them under the boot seal, or by pulling them thru a grommet by the rear lights. Since I went all ghetto I can only describe that route.
The central plastic cover at the rear of the boot has 4 plugs with loops on them, and a smaller central one without a loop.
Picture shows red circled large plugs, yellow shows central small one.
Each plug has 2 slots on the side into which a screwdriver fits.
Use a small screwdriver and pop it into each plug and twist. This causes the top of the plug to pop up. Just pull them out one by one.
When you've got all 5 out, the top of the plastic cover is held on the metalwork with simple clips. Just pull the cover out from the bottom first then put you fingers under top part and pop the cover upwards.
Lift the cover out of your trunk.
Using the wire grabber get hold of the wires which you passed into the bumper and pull them up and out of the gap between the bumper plastic and the metal bodywork.
Lift up the rubber seal and pass the wres under it and into the trunk.
Lift up the trunk liner on the floor and run the wires towards the rear seats.
We now need to remove the rear seats on the driver's side by pulling on the catch under the lower seat, followed by undoing the bolt which holds the upper seat in position..
Now you can use the wire grabber to push the wires from the trunk and into the cabin.
Remove the plastic trim from the door kicker area by starting from the rearmost edge and gently pulling upwards and moving frowards. Run the wires along the door edge to wherever you've mounted your CPU..
Replace the trim pieces and connect your cables to your LI CPU.
I hope this guide has been helpful and feel free to ask any questions you might have.
CCC
Pre install notes
Outside..
Inside..
CCC
