Left wheel sticks out more than right
1 reading
2.7K views 7 replies 6 participants last post by  Ultimateone
#1 ·
Hi guys, i recently realized that my front left wheel sticks out more than my front right. I am running a pretty agressive wheel setup.
Advan GTs 20x10.5 +24 in the front and 20x11 +5 in the rear with 285 squared setup. I have been running this for almost a year and only realized this recently. The left side sticks out approx 5mm more than the right.
Driving not an issue at all with no noises etc too. Just happened to see this while i was washing the car. Anybody has similar issues before or can advise?
#3 ·
I've seen this happen on a vehicle where one of the fenders had been repaired. Has the vehicle ever been in an accident?
Like crainp said, the other possibility is bad alignment or something stuck behind the wheel.
#4 ·
Thanks for the reply! No actually the wheels were bought brand new about a year ago and i doubt there is anything stuck behind the wheel. No spacers at all, stock fenders. I will check the alignment out when i have the time though. However, driving it slow or fast has no sound or vibrations at all as well. Drives as if nothing is wrong with the car. It just bothers me that one side is protruding out more than the other...
#6 ·
If you have not recently done an alignment then you don't know where you are for front camber. It's easy to get readings that are different for each side when driven on the street.
